Identify my cam
Author Topic: Identify my cam  (Read 1070 times)
Offline Dingo80
  • Name: Kyle
Identify my cam
« on: September 14, 2019, 05:41:20 PM »
Can anyone identify my cam for me? Can't find the cam card anymore. I removed the rear welch plug and took a photo of the end of the cam.
Motor is a 351W.
Thanks in advance
Offline Reborn67
  • Name: Andrew
  • Car: 67 Hardtop
Re: Identify my cam
« Reply #1 on: September 14, 2019, 07:11:06 PM »
 " Crane cams Master catalogue" page 216,
  Not the same part No, but the same series/grind...,
  Do like the silicone on the welsh plug, :lol:
« Last Edit: September 14, 2019, 07:16:10 PM by Reborn67 »
Offline Clubman7
  • On the road.
  • Name: Brett
Re: Identify my cam
« Reply #2 on: September 14, 2019, 07:15:30 PM »
  Found this.
Good mid range to upper RPM torque and HP, fair idle, moderate performance usage, bracket racing, auto trans w/2500+ converter, 3200- 3600 cruise RPM, 9.5 to 11.0 compression ratio advised. Good w/centrifugal or Roots supercharger, 10 lbs. Maximum boost w/8.5 maximum compression ratio advised, good w/plate or manifold nitrous system.
Offline Dingo80
  • Name: Kyle
Re: Identify my cam
« Reply #3 on: September 15, 2019, 10:00:25 AM »
Yeh I thought the silicone was good too. They only used it once the plug was in place.
It is a nice drive-able street cam with a little bit of lump at idle. Can I ask how you guys found it as I wasn't sure which numbers were the serial numbers and what the other numbers meant.
Thanks for your help guys
Edit: just searched the crane cam master catalogue and see the H286-2 is the part number. Thanks again guys.
I have one last question. Replacing the welch plug. Is it just a tolerance fit and gentle tap in with say a socket or is there another trick/way to make sure it seals properly?
« Last Edit: September 15, 2019, 10:06:31 AM by Dingo80 »
Offline trav68
Re: Identify my cam
« Reply #4 on: September 15, 2019, 04:12:36 PM »
It is an interference fit and drive in with appropriate size socket, old bearimg race etc etc.
Clean bore in block first and use bit of permatex aviation form a gasket on plug before installing.
Even with an interference fit fluids will invariably leak out (via capillary action)
Offline Reborn67
  • Name: Andrew
  • Car: 67 Hardtop
Re: Identify my cam
« Reply #5 on: September 15, 2019, 04:34:57 PM »
 A little bit of deductive work, and google, the CR was a bit of a clue, possible Crane or Crow, the rest was matching code numbers,
 10 minutes tops........,
