Driveline Vibrations
Author Topic: Driveline Vibrations  (Read 1108 times)
Offline Tarheel
« on: August 21, 2019, 06:49:08 AM »
For some time I had this slight vibration that would come in at maybe around 110kmh.
Last week I had new unis put on the drive shaft and the thing rebalanced.
After fitting the driveshaft back into the car and then taking it out for a drive, I noticed a vibration at 70kmh and 80kmh. The vibration is slight, but noticeable and annoying, especially on a smooth road. I am assuming they have stuffed up on the balancing of the drive shaft, but how can they get that wrong?
When I am doing 80-90kmh and push the clutch in, I feel the vibration too. Maybe even worse initially and then it phases out.
Tyres are all balanced and wheel alignment done.
The vibration is definitely worse since the drive shaft was done.
Is it the drive shaft, or is it something else?
The engine is a 289 with a top loader.
« Last Edit: August 21, 2019, 07:40:55 AM by Tarheel »
Re: Driveline Vibrations
« Reply #1 on: August 21, 2019, 08:57:17 AM »
Is the tail housing bush in the gearbox ok.?
Offline Tarheel
« Reply #2 on: August 21, 2019, 09:13:36 AM »
As far as I know... Yes
Offline big al
« Reply #3 on: August 21, 2019, 10:54:02 AM »
What wheels do you have?
Al
Offline unilec5544
  • Name: Neil.
« Reply #4 on: August 21, 2019, 10:55:11 AM »
Probably a good idea to have the drive shaft balanced.
« Reply #5 on: August 21, 2019, 11:33:39 AM »
:lmao:
Offline Tarheel
« Reply #6 on: August 21, 2019, 12:45:24 PM »
I think I have fixed the issue, or the worst part of the vibration. I saw somewhere a discussion about undoing the rear yoke, dropping the rear of the driveshaft out and rotating it 180 degrees and putting it back. I did this and made sure to not over tighten the u-bolts.
Took it for a drive and it seemed much better. Odd I know, but it is what it is...
Thanks anyway
Online evan
« Reply #7 on: August 22, 2019, 07:42:51 AM »
Thanks anyway
Beat me to it! I went through this years ago after having my tranny rebuilt.
Evan.
