Antenna for new model
Author Topic: Antenna for new model  (Read 1179 times)
Offline Macka
  • Vic member 1571
« on: June 02, 2019, 01:24:57 PM »
I've had a member send a question through in which hopefully someone in here can give an answer to:
Hi Craig,
This is just a little question but I am hoping you can put me in the right direction.
I had friends from the States visit me over April and they brought me a car cover for my convertible.
It is an indoor cover - designed to keep the dust off, not the rain out.
But it has presented me with a minor issue.
The antenna for the 2018 convertible sits on the top of the driver’s side rear quarter panel.
It is about 12” long, flexible and has screw in fitting.
However, if I put the car under the indoor cover this places the antenna under pressure and it bows.
Ultimately I’m thinking that will lead to the antenna warping.
My temporary solution is to unscrew the antenna before I place the cover over the car.
I have sought a “stumpy” antenna version (which would not warp) from my dealer but without success.
They pointed me to Burson’s - got a $ 20 version of something that would suit (ie: the fitting diameter and thread works) except the antenna sits proud of the female socket on the rear quarter panel.
Are you able to point me to anyone on the club who would guide me in getting a solution?
Ultimately, I suppose I could live with screwing and unscrewing the antenna each time I used the car, but that’s a pain I’d prefer not to have.
Regards,
Paul
Offline Macka
  • Vic member 1571
Re: Antenna for new model
« Reply #1 on: June 02, 2019, 01:29:13 PM »
On my covers, I've just cut a small hole in the cover for the antenna to poke through.  What have others done?
Offline 68Coupe
  • MOCA NSW Member
« Reply #2 on: June 02, 2019, 02:11:22 PM »
My Covercraft Dustop cover came provided with an antenna grommet. Custom Mustangs have them -
https://www.custommustangs.com.au/antenna-grommet-for-car-cover
Installation video -
Offline Dazza64
  • I'm still new here
  • Name: Dave
« Reply #3 on: June 02, 2019, 09:01:07 PM »
Offline clive1
  • Car: Mustang GT convertible
« Reply #4 on: February 14, 2020, 08:59:46 AM »
 I had the same issue. I resolved it by buying, from the US, a stubby antenna which is purpose made for the Mustang. I also put a piece of foam on top of the antenna so it does not put any pressure on the indoor cover. Works a treat.
The one I bought was the:
"The Original Stubby Antenna for 2015-2020 Ford Mustang Convertible"
https://www.cravenspeed.com/the-original-stubby-antenna-for-2015-2020-ford-mustang-convertible/
« Last Edit: February 14, 2020, 09:23:14 AM by clive1 »
Offline gbader
  • SAAC Member
  • Name: Greg
  • Car: 65/66/16
« Reply #5 on: February 14, 2020, 10:48:08 AM »
wow - did not realise there were technical solutions - I just us the "cut a hole" method (and pro tip - label the things front/back  :smile01:)
Online USA066
  • Robbo
  • Name: Colin
« Reply #6 on: February 14, 2020, 11:04:23 AM »
We have the used the antenna grommets, work great, but the ones from Bunnings look good to and probably a lot cheaper.
2007 GT Convertible
2008 Bullitt
1966 Coupe
