****** NO LONGER FOR SALE CHANGE OF MIND *******
What was I thinking
Hi All,
I am possibly looking at another vehicle and would be unable to keep both.
66 Mustang Coupe Tahoe Turquoise. 289W Cruise-O-Matic Auto.
Arrived here in 2015, has full reg and will come with plates.
Had all this done for RWC Nov 2015.
T bar shifter bushes
Battery bracket
Fuel pump gssket
Rocker cover gaskets
Sump gasket
Rear main seal - this has a slight leak again
Front brake hoses
R/h / fron brake hose bracket on body
Front castor rod bushes
Both universal joints
Diff pinion seal
Steering ram
Both engine mounts
Rear shackle bushes
Transmission mount
Both inner tie rod ends
R/h outer tie rod end
Both lower ball joints
Front spring saddle bushes
Brake drums all round
Clips and bracket to hold cooler lines.
Since Then
New Edlebrock manifold with 600 Holley Electric choke.
MSD Ignition
Tri Y exhaust with twin system
9 inch diff modified for standard housing
Powered Disc Brake front
Koni Shocks Front and Rear
Koni Front Coils
Koni Front sway bar
Other
Power Steering
Factory Under dash Air - new Sanden Compressor and Condenser ( with thermo fan )
New Aluminium Radiator (internal baffles for water flow) and Derale Thermo fan and shroud.
Upgrade Headlights and wiring
Retro Sound Bluetooth system
Pony timber steering wheel, Dash and glove box
Hump huger Console.
Autometer Temp and Tach mounted to steering column.
GT fog lights and grill.
Interior is in good nick and I have new aqua carpet to go with car.
dash pad needs repair (have a spare not correct colour)
paint is as come form US and has had a respray.
There are a few spots at door bottom and a couple of other places that need to be done if you are fussy but only I really notice them.
Have most of the items I have swapped over plus a heap of other new bits that have not gone yet ( LED tail lights, new heater components, rubbers etc.
Everything works as should.
Great Car to drive stops and handles lovely, gets comments wherever I go.
Looking around
Any questions PM and I'll get back to you.
