Author Topic: VERY RARE 1965 MUSTANG A CODE V8 4 SPEED DISC BRAKES RALLYE PAC  (Read 1186 times)
Online barnett468
This car was ordered with the A code GT engine and has factory disc brakes, plus it has had a dual exhaust system added to it, therefore, it could easily be converted to a GT "clone" if one wanted to do that and it would be much more of a true GT than all the other "clones" out there.
The interior is mostly new and everything that was done was done to Concours show quality standards using only the best and most expensive parts currently available. It was originally a standard black interior but I changed the seats to pony style because they look and feel much nicer. Everything else is stock.
The stock wheels were cleaned then sanded then painted and have brand new, stock size 195x75-14" white wall tires.
The differential is the original 3.00.
The engine is stock except for a very rare Edelbrock 1404 carburetor. It has no vibration and it never smokes under any condition. It runs perfectly and is surprisingly fast.
The clutch is new and is just slightly stronger than stock.
The disc brakes are the original 2 piston Kelsey Hays with the original master cylinder and proportioning valve and they work perfectly. They do not bleed down when stopped and never need to be pumped.
The front suspension has new high performance 610 springs with Monroe-Matic shocks.
The original color was vintage burgundy which is a gorgeous color and is extremely rare.
The sheet metal is all original and the body is straight and everything lines up well. The floors are untouched and dirty looking but still have the original black paint over the factory red oxide primer with no rust holes.
It has both original black and yellow license plates from 1965 and is currently registered.
It needs paint and engine detailing and some other minor work but it can be safely and reliably driven on a daily basis just the way it is.
It runs xlnt and never runs hot. I just drove it 75 miles in 100 degree heat.
Located in Southern California
Price $13,500.00 usd
Re: VERY RARE 1965 MUSTANG A CODE V8 4 SPEED DISC BRAKES RALLYE PAC
« Reply #1 on: May 14, 2018, 07:21:19 PM »
Sounds like a great car
Offline BAC
  • Name: Brian
  • Car: '68 J Code GT 4 speed
« Reply #2 on: May 14, 2018, 08:36:29 PM »
Where have all the trolls gone who continually come on here looking for a nice clean Mustang for $25K?
Brian
