Author Topic: wiring  (Read 606 times)
Offline scott
wiring
« on: February 13, 2018, 10:33:23 PM »
can anyone send me a pdf of the wiring diagram for a 1970 mustang I need the wiring for ac compressor and wire colours
Re: wiring
« Reply #1 on: February 14, 2018, 08:52:43 AM »
Just google it there are plenty on the web, typically the AC wiring is lime green on 67-68, given the factory AC from 67 -70 is very similar I suspect its the same. Its a standalone harness on 67/68 and not part of the main harness, it still uses the original blower wiring though
Online BAC
  • Car: '68 J Code GT 4 speed
Re: wiring
« Reply #2 on: February 14, 2018, 10:04:20 AM »
Had a quick look and most of the standard electrical diagrams don't have the A/C connections included, maybe because it was a low take up rate option?
Keep Googling and I'm sure you'll come across one.
Re: wiring
« Reply #3 on: February 14, 2018, 01:44:41 PM »
Its  a separate stand alone harness, only has about 4 wires the rest is all vacuum controlled in 67 + cars, gets power straight of the back of the ign switch. The green wires are the AC harness the rest is just the standard heater blower wiring in the main loom. Compressor wire is bright green like I said
https://www.google.com.au/search?q=mustang+70+AC+wiring&safe=strict&rlz=1C1GCEA_enAU778AU778&tbm=isch&source=iu&ictx=1&fir=gJJUcAYTqkF5sM%253A%252CQ-KsB2fY6Y9gsM%252C_&usg=__uo-775tngW4mGgyofmizRHWxrlY%3D&sa=X&ved=0ahUKEwiX2IvGsaTZAhUFG5QKHbreAe0Q9QEIMTAB&biw=1852&bih=871#imgrc=3KjuJvMW9n025M:
