Author Topic: correct idler arm location on 65 mustang RHD  (Read 529 times)
Offline wok65
  • Name: Eric
  • Car: 65 mustang
« on: January 12, 2018, 07:32:31 PM »
I was wondering if anybody knows how to get hold of the correct location measurements for my 65 mustang V8 coup Idler Arm. The previous owner installed a 63 Fairlane one & I would like to have the correct one.
Wok65
Online shaunp
Re: correct idler arm location on 65 mustang RHD
« Reply #1 on: January 12, 2018, 09:37:23 PM »
Wok65
Lots of them were converted with compact Fairlane drag links so that may well be the correct one
Offline 67FBGT
« Reply #2 on: January 13, 2018, 09:43:16 AM »
There isn't any 'correct one' as the cars weren't built in RHD. So people wanting to convert had to raid the non-USA Ford parts bin for a suitable RHD substitute and as Shaunp says the compact Fairlane was considered a reasonable and practical match.
Offline PET-289
  • Name: Mick
« Reply #3 on: January 13, 2018, 11:13:53 AM »
I prefer the original factory components for the conversion accept the Rhd steering box
Online shaunp
« Reply #4 on: January 13, 2018, 12:57:12 PM »
I've done few you cant really do that and get the bump steer and turning circle correct. The original ford conversions all used compact Fairlane drag link idler and box. Once you use a falcon steering box you need to make the drag link fit that etc. The best way is to use a factory mustang drag link and cut the ends off then weld Falcon ends to that , then use falcon idler and box. You cant use a falcon drag link as they are too long and the wrong shape for early cars, you can use a shortened Falcon link for 67 on cars. Its no trouble to have the drag links certified to NATA international standard as long as you know how to weld them correctly. They are a forging not cast as many think, so the weld nicely, dye check them as you go then you know the weld pass xray
Offline PET-289
  • Name: Mick
« Reply #5 on: January 13, 2018, 04:55:59 PM »
I have never had a problem with bump steer or turning circle
Offline wok65
  • Name: Eric
  • Car: 65 mustang
« Reply #6 on: January 16, 2018, 02:32:20 AM »
Thanks for your help fellow members
I will get started the long weekend
