Author Topic: Back spacing for best wheel fit  (Read 622 times)
Offline QIK70
« on: January 10, 2018, 07:51:28 AM »
G'day again all.
Next is wheels for my 70'
I'm stuck between the tried and tested 15' centreline or Cragars which will give it the tuff, fat muscle stance.
Or, a bit bigger with 18' and more along the lines of a set of FOOSE rims and a lower profile.
Completely different wheels, I know.
What kind of back spacing will I be needing for the back rims to give me the best dish?
Re: Back spacing for best wheel fit
« Reply #1 on: January 10, 2018, 09:38:43 AM »
I had 18s on my last 70 and they looked a bit big I thought .  A 15 with a tall tyre 27 or 28 inch looked tough .  4.5 backspace is normal . I fitted a 66 mustang 9 inch to give the wheels more outside  dish . The 70 diff is 59 1/4 inches  wide  and the 66 is 57 1/4 so an extra inch dish on the outside dish on rims . A 275/60x15 looks good . You need to test fit before you buy . My old 70 had 15x8.5 deep dish Centerline auto drags for 20 years and they looked great ,and a 10 would have fitted just .
« Reply #2 on: January 10, 2018, 09:41:44 AM »
You can also measure how much clearance you currently have inside & out and then go from there.
Most wheels have the sizing & offset stamped/cast on the back of the rim.  If not, it's easy to work out.
Offline QIK70
« Reply #3 on: January 13, 2018, 12:45:27 AM »
Cheers Glenn,
Trying to get wheels and tyres sorted before she heads off for suspension, so they get the right stance.
 :evilone:
Offline booah
« Reply #4 on: January 13, 2018, 10:05:03 AM »
I can fit a 18X10 with +18 offset (285/35/18R) on the rear and easily a 18X8 with 0 offset at the front......maybe more
