Author Topic: Carburetor advice please  (Read 626 times)
Offline Dave68
  • Name: Dave
« on: December 11, 2017, 02:15:58 PM »
Hello Gents,
After some advice on what size carburetor to run on a 390 FE engine with a new Edelbrock Performer RPM Intake Manifold.
Would a 650 cfm Holley double pumper do the job or try a 750 cfm with the upgraded mainfold?
Thanks in advance, Dave  :thumb:
Re: Carburetor advice please
« Reply #1 on: December 11, 2017, 02:25:20 PM »
If it were me I would go 750 vac sec Holley . Then just change the vac sec Spring Maybe .
  • Boss
« Reply #2 on: December 11, 2017, 05:59:08 PM »
Is the engine stock or mildly built ir a drag racer?
A 650 single pumper vac secondary is fine for a near stock 390 engine and you might run the optional white secondary spring that you get in a spring kit. A 428 cobra jet had a 735.
Offline Dave68
  • Name: Dave
« Reply #3 on: December 11, 2017, 07:18:05 PM »
Thanks guys.
The motor is rebuilt but to stock specs.
« Reply #4 on: December 11, 2017, 07:59:27 PM »
Maybe a 670 Holley street avenger vac sec . Then with a lighter Spring .  If it's a manual then maybe a 650 DP .
  • Boss
« Reply #5 on: December 12, 2017, 12:47:57 PM »
Pretty average quality carb unfortunately and I wouldn't use one on a 390 for sure.
« Reply #6 on: December 12, 2017, 04:18:19 PM »
What's wrong with a 670 Holley ? . I had one on my 347 for years  with no problems and have one on my 351 and it's good also even tho it's a bit big maybe .
Offline boofhead
« Reply #7 on: December 13, 2017, 09:43:49 AM »
if your running a dual plane manifold as I expect with the complete divider and no open spacer then your exposing half the carbi,s flow potential to the ports hence you can/should run a larger carbi.
