Author Topic: 66 coil compression tool  (Read 480 times)
Offline Sjb5856
  • Learning to be a backyard mechanic
« on: December 08, 2017, 04:37:02 PM »
I need to replace upper control arm on my 66 and need a coil compression tool to safely remove/compress the coil springs. Does anyone have these in Perth for hire or sale? Any info appreciated.
Offline skinner36
  • Name: John
  • Car: 1965 FB
Re: 66 coil compression tool
« Reply #1 on: December 08, 2017, 05:22:24 PM »
See if you can find an older rental place (not Kennards) I found such a place here in Melbourne and rented on for $15
« Reply #2 on: December 08, 2017, 05:28:06 PM »
If you're handy, they're very easy to make.   I didn't worry about using a bearing:
http://dazecars.com/dazed/spring.html
« Reply #3 on: December 08, 2017, 07:05:37 PM »
I cut the bottom off a shock and welded it the some threaded rod
