67 Coupe - Vapourizer
Author Topic: 67 Coupe - Vapourizer  (Read 12941 times)
Offline aus_67stang
    • Build page on Facebook
  • Name: Steve
Re: 67 Coupe - Vapourizer
« Reply #25 on: August 01, 2017, 06:48:35 PM »
Yeah that's right, the extension housing is longer on the au's, and I had to relocate the crossmember back as well as the shifter hole. To be honest, having the shifter back a few inches makes it a bit more comfy, but not at the worth of all that work if you don't have to.
It was around 690 for the pedal conversion, around 500 for the thrust bearing, shims, braided lines and reservoir. This was a couple years ago now so may have changed.
I got all the clutch/shifter etc from the states via ebay...much cheaper.
Also, replace the shifter cup bushing with a bronze one you can buy on ebay. The plastic one is pretty crappy, and the bronze one did firm up the shift a fair bit.
ok, not too bad I guess.... I need to adjust the pedal box as the person who done the firewall conversion must have had a bent string line and the firewall / pedal box mounting area isn't square, I need to adjust the mount section to lineup with the firewall alignment... So I have to cut up the pedal box anyway so I may have a hack at it on my own to start with and see how it goes.
I nee the slightly shorter gearbox housing after the frame work that I've done for the seats, if it goes too far towards the rear of the car there will be clearance issues with the uni joint and frame.
Offline Husky350
« Reply #26 on: August 01, 2017, 06:55:20 PM »
I have a few photos of the modified pedal box if you want to use it as reference. I"m not positive, but I think they might use a ba falcon clutch master cylinder.
Offline aus_67stang
  • Name: Steve
« Reply #27 on: August 01, 2017, 06:57:27 PM »
that'd be great, the next rebuild project is the pedal box so it's perfect timing.  :coolpic:
Offline Husky350
« Reply #28 on: August 01, 2017, 07:09:54 PM »
I bought a new pedal box off a guy from the states that adjusts the brake pedal for use with a later model booster, aswell as adding a rollerized bearing. You can buy the bearing off him via ebay, would recommend it. http://stores.ebay.com/MustangSteve-Performance?_trksid=p2047675.l2563
I can also recommend his rear brake disc bracket. It allows fitment of late model mustang discs/calipers. My whole rear brake assembly cost about $800, brand new parts.
« Last Edit: August 01, 2017, 07:11:58 PM by Husky65 »
Offline aus_67stang
  • Name: Steve
« Reply #29 on: August 01, 2017, 07:57:55 PM »
Awesome photos, thanks for the info, a quick hunt and the master definitely looks like a BA type so I know the direction to head from there..... and the roller bearings look good too!!
I already have a set of RRS 285mm rear discs, hopefully they help puller her up nicely.
I've also got a set of Lokar pedal covers and a Lokar accelerator pedal sitting on the shelf, they look pretty good in the photos you have; do they holdup well, after the 3000k's of use?
Offline aus_67stang
  • Name: Steve
« Reply #30 on: September 03, 2017, 05:08:05 PM »
It's been a quiet few weeks, most of the time has been spent research the clutch and brake setup and the approach to take base on all the good info provided by Husky65.
Went for a visit to see the body / paint guy, a fair bit of progress has been made and is in the final stages of prep :D since a bit of work was needed to enure the dash was straight, I decided to have a test fit of the dash before it gets some color.
« Reply #31 on: September 04, 2017, 05:14:54 PM »
RHD I just used a Falcon pedal box and welded the dash end of the mustang one to it. Then falcon booster and Clutch master cylinder from an XB . Then all the pedal ratios are correct. I run a Toploader so it has an external slave and got braided line from Mal Wood.
« Last Edit: September 04, 2017, 05:19:39 PM by shaunp »
« Reply #32 on: September 04, 2017, 07:54:57 PM »
Just caught up with this thread. Great to see another build thread going.
Offline aus_67stang
  • Name: Steve
« Reply #33 on: September 10, 2017, 05:49:01 PM »
Thanks shaunp, still looking at all options, I was going to try and have it done before the car returns from paint have decided to wait until it returns to ensure everything lines up correctly.
Offline aus_67stang
  • Name: Steve
« Reply #34 on: September 23, 2017, 08:17:14 PM »
Today was another step closer, down to see the progress and in stead of the painter preparing a sample paint card he decided to go with painting one of the small panels .... no buffing or polish work, it's a little hard to see some of the metallic effect in the photos but the video is better.
Video of the panel:
Then on to modifying the door lock mechanism to accommodate the central locking solenoid.
Offline Husky350
« Reply #35 on: September 23, 2017, 10:44:57 PM »
Nice job on the solenoids, they look pretty big. Looks so much easier to do it with the locks out, can't believe I installed them with one arm through the door with only my sense of touch to guide me.
The colour looks great too. Is that what the exterior colour will be?
Offline aus_67stang
  • Name: Steve
« Reply #36 on: September 23, 2017, 11:42:31 PM »
its strange how large the solenoids look, I think it looks worse because they are closer to the camera / phone :(  and was much, much easier out than what it would have been in the car.
Yup, thats going to be the external color too.... Its a 2006 BA colour called Ego.
« Last Edit: September 23, 2017, 11:44:49 PM by aus_67stang »
Offline USA066
  • Robbo
  • Name: Colin
« Reply #37 on: September 24, 2017, 12:05:21 AM »
Solonoids look about right, quite large.  I screwed mine to the door frame behind the panel and connected the rod through the eyelet and clamped it to the lock rod on my 66. Works fines. A lot better not having to use the key. Nice colour to.
2007 GT Convertible
2008 Bullitt
1966 Coupe
« Reply #38 on: September 26, 2017, 08:30:42 PM »
You are doing it gloss inside? they were satin origianlly
« Reply #39 on: September 26, 2017, 08:44:20 PM »
Bookmarking this page for the power door lock photos  :cheers:
Offline aus_67stang
  • Name: Steve
« Reply #40 on: September 28, 2017, 04:10:26 PM »
I was trying to work out how to mount them in the door and not having it fowl the window, etc., since I'm removing the external door lock I thought this would work well too.
You are doing it gloss inside? they were satin originally
shaunp, still going gloss, I know it's not standard but there's going to be a few things that won't be original so it will sort of work (hopefully) :)
Cool Dwayne, hope they help a little for future reference.
« Last Edit: September 28, 2017, 04:14:13 PM by aus_67stang »
Offline aus_67stang
  • Name: Steve
« Reply #41 on: November 13, 2017, 10:51:32 AM »
The long wait is now over, the old girl has arrived home all dressed up and ready for the dance  :pepper:
you can see a short video of the colour:
and now it's time to start putting everything on her, below is the fuel cap reassembled :)
« Last Edit: November 14, 2017, 05:43:47 PM by aus_67stang »
Offline Azz67
« Reply #42 on: November 13, 2017, 04:41:45 PM »
That looks sick and will look even better with shiney chromey bits on it..
Well done mate.  :evilone:
Offline aus_67stang
  • Name: Steve
« Reply #43 on: February 18, 2018, 09:55:53 PM »
There's been a few updates over the past few weeks...
- Tail lights & backup lamps sorted
- I'm using Car Builders heat and acoustic insulation in the roof and then the headliner all done
- rear glass is in
- all the door rubbers & window to roof rail seals done!
- rear 1/4 windows in
- California Pony Cars mirrors painted and fitted
a pity the sun wasn't out for most of the time but still get to see the sparkle now and again :)
« Last Edit: February 18, 2018, 09:58:07 PM by aus_67stang »
Offline StephenSLR
    • www.lycanthia.com
  • Car: 1965 Fastback
« Reply #44 on: February 19, 2018, 07:42:07 AM »
I find that the previous owner decided to replace the rear qtr, but instead of getting new replacements he gets a rear qtr section from a junked mustang. He unpicks some of qtr (at the door jam and roof sail (if you call it that) but the just cuts  around the inner wheel well and past the tail lights so he doesn't have to unpick & weld all those spotwelds.
You're lucky, there was a pic here of one PO that welded the new quarter on top of the old one, lol
s
Offline aus_67stang
  • Name: Steve
« Reply #45 on: March 21, 2018, 07:41:06 PM »
More progress :)
Finally got around to doing the Pedal box, sourced a BA / BF manual setup and used both the clutch assembly and brake pedal which means the pedals no longer point to the left. Everything had to be customised to the firewall and not a standard pedal box since it is so out of whack.
I also used the BA switches for the brake and brake fail lights.
to:
Offline davigg
« Reply #46 on: May 05, 2018, 11:46:32 AM »
Love seeing the effort you put into this beauty, man. Keep it up
Offline aus_67stang
  • Name: Steve
« Reply #47 on: May 06, 2018, 09:25:25 PM »
Thanks Davigg
Offline Husky350
« Reply #48 on: May 07, 2018, 08:49:32 AM »
Pedal box looks great!
Offline aus_67stang
  • Name: Steve
« Reply #49 on: May 07, 2018, 07:58:47 PM »
Thanks Husky65 :)
