Author Topic: Login problem  (Read 1273 times)
Offline jademustang
Login problem
« on: May 20, 2017, 06:39:27 AM »
I can't login using the "normal" login under the club logo, after entering my username & password and click login in it says "Your session timed out while posting. Please go back and try again." The login that sits between register & search works.
Happens on the computer as well as iPad.
Offline mustang_talk
  • Name: George
Re: Login problem
« Reply #1 on: May 20, 2017, 07:53:49 AM »
I have the same issue. Has been happening for about a week now.
Offline birdman
  • Name: John
Re: Login problem
« Reply #2 on: May 20, 2017, 09:44:43 AM »
Same on my end.
There's another thread posted for this issue.
http://www.mustang.org.au/forum/index.php/topic,32169.msg309245/topicseen.html#msg309245
Re: Login problem
« Reply #3 on: May 20, 2017, 09:50:34 AM »
Yes on another thread and I have  still got the same problem .  After it shows that I just go to log on again and that works  :shrug: :shrug:
Offline peterp
  • Administrator
    • http://www.yourithelp.com.au
Re: Login problem
« Reply #4 on: May 20, 2017, 12:55:17 PM »
Hi Members, It does seem that the last forum patch that was applied about a week ago does have some issues that are noted on the SMF Support forum.
I am looking into what we can do to resolve the situation.
Regards  Peterp
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the Duct Tape.
Offline birdman
  • Name: John
Re: Login problem
« Reply #5 on: May 20, 2017, 01:13:59 PM »
Regards  Peterp
That's cool, I'm more concerned about the (Not Secure) popping up in the address bar
Offline robbie
  • I don't even...
  • Name: Robbie
Re: Login problem
« Reply #6 on: May 20, 2017, 02:30:21 PM »
You're seeing that because this site isn't run under SSL(https as opposed to http), which in an ideal situation it probably should be.
Offline peterp
  • Administrator
Re: Login problem
« Reply #7 on: May 20, 2017, 07:33:58 PM »
Yes we want to apply an SSL Cerificate to the forum but unfortunately at this point SMF doesn't support it.
There is a new version of SMF V4 which we will be upgrading to as soon as it is available, after the upgrade we will be able to apply https to the forum.
Regards  Peterp
Offline birdman
  • Name: John
Re: Login problem
« Reply #8 on: May 20, 2017, 08:08:07 PM »
Yes i know and i also agree.
Offline jki789
  • Name: jetr
Re: Login problem
« Reply #9 on: July 12, 2017, 08:02:58 PM »
Seems it also happened to me once but now solved when i restart the system.
