65 Fastback A code Nut & bolt resto
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
News:
Menu ≡
Help
Login
Register
Help
Login
Register
Mustang Forum
Technical & General Discussion Area
« previous
next »
Print
Pages:
1
4
5
6
Go Down
Author
Topic: 65 Fastback A code Nut & bolt resto (Read 55055 times)
65FastbackAcodeRestoration
Thoroughbred
Re: 65 Fastback A code Nut & bolt resto
Reply #125 on:
November 07, 2016, 08:19:50 PM »
Nearly all of the body shell now complete apart from some minor dents to LH rocker panel...
Logged
mwizz
Shelby
MOCSA member #827
mwizz
Reply #126 on:
November 07, 2016, 08:51:21 PM »
Looking good
Logged
Thoroughbred
Reply #127 on:
November 08, 2016, 06:46:26 PM »
Thank Mwizz, pretty stoked to see the project reach this stage, hanging panels still need some work and epoxy.
Logged
Thoroughbred
Reply #128 on:
November 12, 2016, 12:09:07 AM »
The dents to the LH rocker panel are now pulled out, lead-wiped & filed.
The LH door original skin has been taken off but seems there is a fair bit of surface rust inside so i'll get this blasted possibly tomorrow before the new skin goes on...
I've also been putting together the new headlight buckets tonight to check for quality and fitment...I've used the NOS headlight surround on the RH side because the repo one was a shocking fit within the bucket.
Logged
Thoroughbred
Reply #129 on:
November 12, 2016, 02:33:50 PM »
got the new floor, inside of rear quarters, rockers, and ceiling in epoxy today, starting to look like a nice clean slate!
Logged
Thoroughbred
Reply #130 on:
November 12, 2016, 02:34:33 PM »
Logged
Thoroughbred
Reply #131 on:
December 08, 2016, 12:58:27 PM »
Front pillars have been re-wiped with lead.
New LH door skin is done and the few rust holes to bottom of the door have been patched...
The inner door shell will need to be media blasted again as the epoxy did not stick...good thing only one panel has been blasted by that mob...
Logged
Thoroughbred
Reply #132 on:
December 08, 2016, 12:59:22 PM »
Last Edit: February 19, 2018, 09:29:49 PM by 65FastbackAcodeRestoration
Logged
unilec5544
Worked
unilec5544
Reply #133 on:
December 08, 2016, 07:49:27 PM »
Getting really close now, were the door skins welded on or did you use an epoxy glue?
Logged
Macka
Shelby
Vic member 1571
Macka
Reply #134 on:
December 09, 2016, 05:25:15 PM »
That's coming along well now and in seeing some old school remedies in there will make it a nice resto..
Logged
Thoroughbred
Reply #135 on:
December 23, 2016, 08:43:47 PM »
Door skin was plug-welded and has bronze welds to corners...
Logged
Thoroughbred
Reply #136 on:
December 26, 2016, 02:42:19 PM »
Metal work all done. Now to save up for paint........
Logged
mk1_oz
Worked
I'm new here
mk1_oz
Reply #137 on:
December 26, 2016, 04:22:38 PM »
sweet
Logged
mwizz
Shelby
MOCSA member #827
mwizz
Reply #138 on:
December 26, 2016, 09:58:30 PM »
It looks cool just sitting there like that
Logged
unilec5544
Worked
unilec5544
Reply #139 on:
December 27, 2016, 08:59:31 PM »
If you can get the engine bay painted then you can at least do all of the front suspension and even get the engine and tranny in.
Logged
Thoroughbred
Reply #140 on:
January 02, 2017, 03:59:33 PM »
I've got the engine bay paint so that will definitely be my next step. I'll leave the exterior paint to a pro !
Logged
Thoroughbred
Reply #141 on:
December 09, 2020, 01:31:35 AM »
URGENTLY need a 65 4 speed toploader original prefer rebuilt and prefer code HEH-BT C5AR-7006D but will consider a rebuildable toploader -don’t mind where in Australia it is located please PM with any leads! Need ASAP to complete the restoration!
Last Edit: December 09, 2020, 01:33:31 AM by 65FastbackAcodeRestoration
Logged
GEOFF289
Blue Printed
GEOFF289
Reply #142 on:
December 09, 2020, 12:29:08 PM »
PM sent, but don't get your hopes up.
Logged
Print
Pages:
1
4
5
6
Go Up
« previous
next »
Mustang Forum
